What will fix this? It works with the headlights on but not when they're off.
Checked all that and didn't find any bad fuses. I was told it was the Headlight Control Module Ballast that's mounted to the bottom of the light. This part held on with four screws.May have something to do with the turn signal switch. When the turning signal is on, the daytime running light on the same side goes off, but the other daytime running light will stay on, until the turn signal goes off.
I watched a video on how to remove the headlights. I'll pass.Cpuld be. Csn you tske it off and see if its got some dirty in the connector or anything?
