I'm with Fishn. I live in a rural area, and the best thing is a set of auxiliary lights, wired to your high beams. That way you don't blind anyone when you hit the dimmer...Have you though about mounting a light bar in the lower grill?
That's the best option you'll have, but be prepared to shell out some cash. A decent set of projectors and bulbs will be about $400. This is if you do the retrofit yourself. If someone does it for you then add labor on top of that.Oh okay I guess I will be looking for a set of the retrofit style headlights next!
Have LED bulbs on the way. Is there a specific orientation for them, LEDs top and bottom or side to side? I haven't got them yet so no idea what the instructions might say.I have Retro-Solutions LEDs and they are pretty bright. These are my low beam comparison. The third pic is with LED fog lights. The fourth pic is my high beams before I was done adjusting them. If that is not bright enough then you might need a light bar.![]()
Sent from my SM-G930V using Tapatalk
I just installed them as I would with the regular bulbs. Insert and twist until it hits the stop. I haven't had any issues.Have LED bulbs on the way. Is there a specific orientation for them, LEDs top and bottom or side to side? I haven't got them yet so no idea what the instructions might say.
The deer you hit you will never see coming (in time) and it won't be from lack of light. My experience anyway. Aim lights a little higher and install new bulbs. Can pay deductible with money saved..Need some honest opinions on this looking to upgrade to hid or led, need some bright ones! I drive 30 min to work in the middle of the night in Montana and deer/wildlife well there everywhere. Any suggestions would be appreciated!
