So the valve went out just like i thought it would since it's something "normal" on the titans. Cheap part i guess. So instead if replacing it with the same cheap valve that cost $100 and will eventually fail again, has anyone found another alternative to the oem valve. I'm considering trying out a ball valve like this one and just opening it up on winter months and shutting it off in the summer. I have the wiring harness unplugged now since the clicking when you turn off the engine is annoying. Any thoughts if this might work before i try it out or has anyone tried something different.
