I have 3 500's (driving pattern) mounted upside-down like others too.
When I installed them, I used my own wiring, mil-spec 14AWG (you can use any 14 AWG, I'm just being snobbish) for each run to each light, a 75A Tyco relay and 8 AWG mains wire with a 30A fuse. I plan on putting in 100W bulbs, so that is why I beefed up the wiring as the stock wiring kit is too chintzy to handle 100w bulbs.
Anyways, I also researched HID kits and 100w bulbs. Here's what I found:
HID retrofit:
The beam on the regular 500's is only so-so with a HID retro. The beam on the 500FF's is just horrible. The FF reflector does not play nice with the arc of a HID bulb. Just Google "500FF HID retrofit" and look at Google images from all around the web. Basically, it takes your pencil driving beam and turns it into a splotchy pinpoint beam.
http://www.fullsizechevy.com/forum/...r-tech/393381-hella-500ff-hid-conversion.html
If you must do HID, please stay between 4300K and 5000K color. Anything else is just for show, and honestly you can't show off your HID 500FF's on public roads....
100W upgrade:
100W bulbs burn out faster than 55W. Colored 100W bulbs burn out pretty much in a few hours. Stick to name brand clear 100W bulbs. Auto parts stores have Sylvania's for about $8-10 a piece.
You should beef up your wiring accordingly to handle the 100W bulbs, but others have stated that a Hella 2 lamp kit does handle 200W fine. I wouldn't bet on it.
No one ever experienced melted housings, when asked people stated they never melted. The reflector is metal, and the lens is glass. So, I wouldn't doubt the plastic housing will soften a bit when hot, but it should be OK.
People were mighty impressed by the performance of the 100W bulb. Everyone stated it was a huge upgrade. I would say it is better than HID since the beam is useful and very bright despite not being HID.
Remember, colored bulbs are bad. They burn hotter and die sooner, and they are less bright.
I'd tell you how 100W bulbs worked for me, but we are getting 16 hours of daylight here so I'll have to wait a while to trail test them at night....
