Hey guys as the title states I have a 2009 Titan that will no longer start. I was driving it when the chip fell out of the key (key was broken earlier that day) at which point the truck died. I was able to start it up 2 more times while holding the chip next to the ignition. After that it would no longer start. I went and bought a new key from the dealership, still no luck. The vehicle immobilizer light is still staying on. I have attempted the following: Disconnect the battery (4 days strait to make sure), switching the ignition on for 5sec and off for 10sec (multiple times), The step by step procedure to reset the ECU, using the key fob to unlock the truck, all have failed. When your turn the ignition over you can hear a relay hitting, but the stater will not engage. I am at a loss and losing my mind. I really don't want to go to the stealership and get taken for a ride. If there is anyone who can help i would greatly appreciate it. Thank you.
