[WIP] *UPDATED* 2006 Flex Fuel Titan 4x4 with 2009 Flex Fuel VVT Engine Swap
Posted this in electrical, but this is also engine related, so hey more the better.
Hey guys, *second* time poster here but we have came to a screeching halt outside on my dads titan. I am here to ask for help because i need to get him back going. His motor locked up SOLID (breaker bar will not budge it) the other night while mud riding and in that causing him to slide into a tree. all i knew at the time was engine code B should work. So i found one with 40k on it for 1700 bucks and we went and picked it up 5 hours away. This is indeed a 06 with Flex Fuel, so i found a flex fuel engine vin B and this is what i get.
New MOTOR (Cam position sensor moved to front of head
Old MOTOR, (Cam Position sensor is on the back of head)
Now the new issue, we finally got the engine pulled and you guessed it, wiring was looking a little different. Got to surfing the web and it seems that 07+ has VVT and VCT Solenoids in the engine. I have a ford so i know what all that is of course, but the help i need from you guys is simply this.
What computer model do i need to make this work? It has to be a 4x4 computer w/ tow mode of course i comprehend that, but does anyone have the part numper or model??? There are like 10 different ones, the latest looking one being like a 5J ECU. If at all possible i need the wiring harness part # too because i am searching everywhere and am currently unable to find one. This truck is a beast and needs to be back on the street ASAP as it is his DD. Any help would be greatly appreciated!
