1 - 2 of 2 Posts
Hey, I have a 09 SE with the Rockford Fosgate system inside. Ever since I got it I noticed that the audio would only play out of the left side when I would use my aux chord to play music from my phone. I looked on the forums and such and everyone said change your aux chord... So I did. FIVE TIMES with no difference. Does anyone know why this is happening and how I can fix it? Also, my fader isn't set all the way to the left. AND when I use the radio it plays through every speaker.
I know that you have changed the cord several times, but are you sure the AUX cable has stereo connectors and not mono?
If you are using the correct cable to connect (and the source is in fact stereo) then the most likely problem is the contacts on the socket in the dash are sprung such that the right channel contact is not touching the plug when the AUX cable is plugged in. To check you will need to separate the radio bezel surrounding the radio and visually check for contact with the plug at the AUX input.
1 - 2 of 2 Posts
