Help, broken wiper blades
1238 4
I went to thaw the T out of the snow, and the wiper blades moved an inch or so and stopped. Whats the fix? The arms move freely like nothing is hooked up. I am going to pull the wifes Murano out of the heated garage and see if I can squeeze the T in there to thaw out.
This sounds expensive.
any advice or part numbers will help.
dave
is there any ice or snow on the windshield of the T?
a little. mostly snow. I pulled it into the garage to thaw out.
Oh I was gona say maybe there's too much snow so the wipers arent strong enough to work but it could be a burned out wiper motor?
Update. I removed the wiper blade arms, removed the plastic cowl piece, and found the nut/lock washer that hold the attaching arm to the motor just laying in there. Reattached everything and I'm back in business. I guess it just came loose. Afterwards, I wish I had put some loctite or something on it, but hopefully she stays tight. I'm soakin wet and freezin, but its always fun to work on the Titan!
