1 - 3 of 3 Posts
accidentally posted in the 1st Gen forum
i did a little searching but wanted to ask anyway, just to be sure.
2018 Titan
on acceleration fan is very loud...sounds like a dump truck.
at cruising speeds it seems to quiet down.
happens randomly, but seems to happen more if i have the ac turned ON
is this just a bad fan clutch? i would think so, but not sure given it seems to happen more or less often depending if the AC is on or off.
sounds like one. sometimes you can tell by how easily the fan turns when you open the hood and just push the fan with your hand.
2018 Titan
Yes that is how the typically go out…it’s gradual then eventually stays fully engaged…
If dealer gives you trouble ask to ride in a Titan off the lot to compare…
A failed fan clutch doesn’t throw any light or codes that I am aware of…
1 - 3 of 3 Posts
