So UCA install should be simple... Remove spindle, remove bolts, remove UCA, grind down little things on the inside of the brackets, replace UCA, replace bolts... Sh!t they don't fit!
This is where I'm stuck. I'm on the driver side and the front bolt fits fine, no issues. The rear part of the UCA cannot push back far enough (in towards the engine) to get the bolt in the hole. I can't find anything on having to grind part of the UCA and/or part of the bracket down to get this to fit.
Any help greatly appreciated as my DD truck is sitting with no UCA on it.
First picture is the front of the bracket, second picture is rear.
