***Ended up being a dead battery, total coincidence***
Hey guys, I need help.
I attempted to wire up the relay and stuff for this mod and it didn't work. Put everything back to stock. Now I can't start the truck normally.
When I turn the key to the "on" position everything acts normal with the gauges. When I turn to crank it, it just clicks and the gauges flicker for 5-10 secs and go back to normal. I can jump her and get her started and everything is normal. I can turn the truck off and wait 30 secs and restart her ok. If I let her sit longer than 3-5 minutes it has the same issues again. Turn the key, won't start & clicking noises, gauges flicker, then the gauges go back to normal.
After I jumped the truck the first time I tested 4hi, 4lo, and the locker and it's functioning perfectly.
I checked a few fuses: rear diff in the cab fuse panel & ignition fuse under the hood. Both looked ok. There are so many fuses, I don't want to start pulling them all. Can someone help me narrow down the fuses that may be related to these issues?
It seems like the battery is low or dead.
Any help or advise is much appreciated.
