1 - 18 of 18 Posts
Any CEL?
What year, how many miles?
I'm no mechanic!
As far as I know, that valve just opens when the truck is running to allow fuel vapor back into the intake. Don't think it would affect fuel pressure.
Are you getting a CEL?
Could be your ECM relay going bad.
Have you tried any fuel treatment? You may have some water in your gas.
Possible causes: Wet or Dirty Air Filter, Fouled or Worn Spark Plugs, Broken Spark Plug, Failed Cats, Failed Fuel Pump, these are just a few things. Don't worry, just get it properly checked to find out what has happened.
What maintenance have you had done?
this sounds like some of the symptoms guys have referred to with the failed cats. Read some of the million threads here about it :bangit:
sounds like the cats clogged for one
spark plugs next since these need replacing around 100k
Cats and plugs would be my guess. Actually sounds like coil packs going bad, but I don't think our trucks have them, which makes me think plugs more than anything. fuel pump would be something to check out as well.
1 - 18 of 18 Posts
