I picked up a set of OEM side steps, and I was sanding them down for bedliner when I decided to match them up under the truck to see the install. My truck has 3 bare spots where it looks like the brackets used to go (not sure if this is all titans, or if steps were taken off my truck before)
I see 3 threaded studs sticking out of the truck. These match up with one of the 2 top holes on the brackets. Does the second top hole stay empty?
My steps also came with a nut/bolt combo in this second hole, however I am not sure where these actually go.
Does anyone have pictures of the underside (mounting) of their OEM steps? If my description is confusing I can take some pictures.
