help questions about a leveling kit on a 04
757 Views 8 Replies 5 Participants Last post by  gmo
ok im new to these forums and to my titan and i was wondering if i could run 33's on my 2004 4x4 SE cc with out a leveling kit ? and my other consern is that if i do install a leveling kit i hear some people have problems with rubbing or clicking noise after it's done and would it change the front axle angles ? any input would help thanks GMO
1 - 9 of 9 Posts
Im leveled and have no issues, nor have i ever heard of any that you discribe. I think if you try and run 33s u might find that you will rub. In that case, you may need to install wheels spacers and/or do the pinch weld mod.
I have the NCD kit--for $72, you really cant go wrong. PRG also sells it--but for almost double. the only difference, the PRG kit comes with bump stops. You can buy bump stops from autozone or pepboys for about $12 (if you want em).
The tallest level kit you can do on the front is 2". I have the PRG kit. Simple install, only took a couple hours.
Reactions: gmo
You can run up to 33" x 12.50" tires on stock wheels with no leveling kit and no rubbing. If you have aftermarket wheels with negative offset then you might get rubbing and need to do the PW mod. I didn't put a leveling kit on my truck due to the number of people with leveling kits who have had their front axle shaft pop out of the differential. Very few people with stock Titans ever have this problem. If you read the front axle failer thread, you will see that the vast majority of people who reported their axles popping out had leveling kits on their trucks. That being said, there are lots of folks with leveling kits that have had no issues; however, every person I know who had their axle pop out of the front dif has a leveling kit, and nobody I know with a stock Titan has had this problem. I'm going on 6 years with no issues (knock on wood), and I thrash my truck like it owes me money. IMO, installing a leveling kit is not worth the risk of ruining your front dif.
http://www.titantalk.com/forums/titan-problems-dealer-service/68142-front-axle-failer-thread.html
Reactions: gmo
1 - 9 of 9 Posts
