1 - 9 of 9 Posts
Not certain, but on many of that era (I'm an 06 CC) that did not have factory fog lights, the plug was still wired in place. Mine did not. It varied for no set reason....I made my own OEM style harness, right up to the IPDM and installed the appropriate stalk. So, that is what I think it is. You would still have to get the stalk, which is cheap and easy to install. Add lights and away you go.
I have Factory Fog light wiring on this Titan but its right next to the Fog Light location.
This plug is just hanging there by itself.... def not for foglights.
I had my front grille off recently, and there is a harness plug going to something mounted above the fan. It's covered with like a metal plate, doesn't look like a plug woukd go there. I'm still not sure from your pics what exactly you referring to, but that could be it.
That might be an airbag sensor. It could be some sort of thermostatic control, but my money is on airbag sensor.
1 - 9 of 9 Posts
