if it won't go into gear that means the burn out mod is "ON" and a full throttle burnout is possible.. turn the switch "OFF" and then you can change gears..
well the thing is, I dont even have the switch on it, I dont have anything connected to it anymore, and I connected the red/green wires back and it still wont go into gearToomnymods said:if it won't go into gear that means the burn out mod is "ON" and a full throttle burnout is possible.. turn the switch "OFF" and then you can change gears..
Checked the all the fuses a 2nd time and no blown fuse.Toomnymods said:mustve blown a fuse..
tried a test lite and no power to it, check all fuses, just started my truck to try again and these codes were thrownToomnymods said:i'd advise getting a test light, somthing is blown somewhere.. trace the wires, some go to the ecu, check the fuses under the hood also..
prob blew up the switch that allows ur truck to shift gears.. i dunno might have better luck finding help on the other titan site.. i dont know much bout the tranny but im sure someone on c l u b t i t a n could help yaDom249 said:tried a test lite and no power to it, check all fuses, just started my truck to try again and these codes were thrown
anyonw know exactly what these are?
-------- ECU --------
Found: 2 codes!
U1000
U1001
U1000 CAN* Comm Circuit
U1010 CAN* Comm
^ this is what they are I found but more info on what they are?
