bigfatboss said:
Order a xe bezel from Nissan its the best
bigfatboss said:Okay the confusion is setting in here. I just purchased a Clarion MAX675VD head unit.... double din setup. I am trying to find the right installation kit to use. Can anyone point me in the right direction? It shopuld be straight forward. I don't have the separate climate controls and its the standard 6 cd player, no Rockford Fosgate. Any help would be appreciated. Thanks
it depends on year of the truck and if you have dual air or not.jpourciau said:I'm confused. I thought that you would need an aftermarket kit for that?
Oh ok, that makes sense. I have an '08 CC SE, with the 6 disc changer, not RF. So, if i wanted a double din nav/dvd I would have to get the aftermarket kit that was just released?tech12volt said:it depends on year of the truck and if you have dual air or not.
here it is with a picture.jpourciau said:Oh ok, that makes sense. I have an '08 CC SE, with the 6 disc changer, not RF. So, if i wanted a double din nav/dvd I would have to get the aftermarket kit that was just released?
does that replace the whole grey bezel that is there now?
