I have been searching for a while now and I am ready to order so I want to make sure it is right. I am getting the pro comp 6 inch lift with 20 inch chrome rockstars. My questions are about wheel width and tire sizes. Which option do I need? Will the 10 inch wide weels fit and will 35/13.50/20 fit. I want to go as big as possible without rubbing issues.
option 1
20x10, 6 on 5.5 / Bolt Pattern
Back Spacing = 4.56 in.
Offset = -24 mm.
Hub Bore = 108
Finish = Chrome
option 2
Offset = -24 mm.
Hub Bore = 78.1
Finish = Chrome
option 3
20x8.5, 6 on 5.5 / Bolt Pattern
Back Spacing = 5.14 in.
Offset = 10 mm.
Hub Bore = 108
Finish = Chrome
option 4
Offset = 10 mm.
Hub Bore = 78.1
Finish = Chrome
option 1
Offset = -24 mm.
Hub Bore = 108
Finish = Chrome
option 2
Offset = -24 mm.
Hub Bore = 78.1
Finish = Chrome
option 3
Offset = 10 mm.
Hub Bore = 108
Finish = Chrome
option 4
Offset = 10 mm.
Hub Bore = 78.1
Finish = Chrome
