I have the same lift and I have 8.5 inch wide wheels with 0mm offset and with my 285/70r17s It only rubs the pinch weld area at full lock. You would want to go with the +12mm offset which would bring them in more so that they dont rub so much. Take a look at my photos and you can see some good shots I took of how much the tire sticks out.I bought the PRG 2.5" leveling kit for my 2006 Titan XE CC and was wondering what offset I need to fit 295/70/17 Nitto Terra Grapplers. I will be purchasing Incubus 816 Crusher rims that are 17X9 and they offer a +12,-12, or 0 offset in these rims. I would like them to fit without rubbing or cutting involved. If the tires fit with any of the offsets I provided, then I would like to know which one would stick out the most because I like that look. Thanks a lot in advance!
If the sticking out look is what you want, you would have to go much higher to get the clearance.
