1 - 3 of 3 Posts
this is on my wifes 2006 xterra with 33k miles.
truck won't crank but all interior lights are on and the clock keeps same time. replaced battery still same problems. i switched around the relays and still no change..
any help? we had to leave it at her office.. may have to have it towed to the dealership tomorrow if i can't figure it out..
what yall think could be wrong?
I would put the key to the run position, press the brake and move the gear shifter into gear and back into park. Then see if it cranks and starts. That's all I think of in a no crank situation with a new battery and good connection, unless you blew a fuse somehow.
It was doing it yesterday and i jiggled the positive side terminal and it started up. Thats not working now
1 - 3 of 3 Posts
