I bought a 2008 Titan Pro 4x two weeks ago. I really don't off road other than driving on the beach during the summer. I'm starting to see that it's very difficult to lift the truck enough for 33" tires without actually installing a lift. Unfortunately, I can't afford to do that. Has anyone run into this issue, and is there a solution? Summer is coming and I need answers!
Throw a 1 inch leveling kit on it and you should clear 33's no problem. I did it on my 09 SE and had no problems. A PRG spacer will run you around 100 bucks.
Pro4X comes stock with 33's... 275/70R18 is 33.1x11.
Reactions: Nick Name
pretty sure thats not a 33. Isn't that more like a 35
why don't you go with a toyo at2 325/60R18. thats a 33x13 and has a 50k? warranty.
305/70R18 is a 35x12. Will need to do more than just a leveling kit for that. Lose the mud flaps, possible PWM. 305/65R18 or like Honda said a 325/60R18 would be easier to deal with. The wider tire would do better in sand anyway.
