Looks good. How come you didnt like the stock flares/trim? And where are you gonna put the skid plates?
Thanks. The stock Pro-4x flares weren't wide enough to keep the gravel away from the body. I also plan on getting wider wheels/tires so I figured the pockets would serve nicely.
The skids are going to take a bit of tweaking. The setup of the T sucks @$$ compared to my 06 Frontier. The Frontier had everything tucked above the frame so it was easy.
Depending on which grade Al I go with, I may or may not bend. I'm thinking 0.25" or 0.40" (again depending on grade) will hold up nicely to moderate trails. With the engine plate, I'll have to cut around the LCAs and the stock skid.
Until work slows down, (not holding my breath) the skid and bumper schematics will just in .dwg limbo.
