Hello all,
I've noticed a few posts about high-octane gas usage. I thought you might find the following interesting. This information is straight from a Chemical Engineer.
1. The "octane" rating on gas only refers to its ability to RESIST detonation. Basically, the higher the octane, the more you can squeeze it and heat it before it explodes. Very high performance engines use high-octane gas because their high compression ratios and/or blowers necessitate it.
2. High octane gas has LESS energy potential than low octane gas. Putting high octane fuel in your car REDUCES horspower output, because you're using a fuel with less energy potential per gallon.
3. If you FEEL like your car puts out more horsepower when run on higher octane fuel, it may be that your engine is out of tune, and that the higher octane gas is reducing pinging, thereby reducing the amount your electric engine management backs off the timing.
4. Using high octane fuel on an engine that doesn't require it can actually create an engine that's an "octane junkie". The cooler burning high-octane fuel can leave carbon deposits, that effectively change your compression and create hot-spots in your cylinders. This increases detonation, and requires the high-octane fuel to prevent it.
Anyway, this info is from a pretty reliable source. Take it for what it's worth!
Half Shovel
Half Shovel
