High speed noise
1.4K views 3 replies 3 participants last post by  stokie
I was recently running at a hight rate of speed for about 3-4 hours and started to hear a noise from the from of the drivers door front fender area , sounded like a loose wire or cable . Dealer could find anything loose and remove the fenderliner and found nothing out of place. It only happened between the speeds of 82mph and up. Anyone have anything like this happen?
#2 ·
I have the same think happening to me. Been for a year now. Nissan Rep is going to take a test drive with me soon. I hope he can help as the dealer can't find it.
What happens to me there is a tick that kind of sounds like a misfire but not really, or a arc spark sound. If some one knows what is causing this please post. Its on the drivers side. Happens at 75mph but more at 80mph intermittently.
#3 ·
"hi ya" i think i may have had the same thing. at high speed i herd a noise that i asumed was coming from the frount driver side of the fender. well in my case as i was driving it only happend every so often but the noise was found under the steering wheel. if you look under the dash center of the weel you will find a steal brase on the brase is a bolt wich is fitted to the bar give it a good wak!! if it is loose bingo!! good luck if it is not it pm me i have moor to try :cheers:
#4 ·
It has been fix my high speed noise aka tick. This one is the divers side area sound like its from the back of the engine driver side.
The cause was the shroud next to the windshield it lifts at high speed and then bumps the body. Fix is some foam so it doesn't rub.
