I'm not sure which one is on the canister but I know on most you just pinch the tabs in on both sides and pull, if not there's a c clip one that you pull both legs out and remove the pin entirely to release, and one that you twist the plastic collar on and pull. The only one you need a tool for are the metal collared ones like the ones that connect to the fuel rail.
