1 - 8 of 8 Posts
How do you verify that a Titan has had a 2* advance done on it? My truck feels different than it does when I got it last year. During the summer they followed the instructions I provided for the 2* advance but was never 100% sure since they didn't give me a before and after timing value and when I asked what it currently was set to I didn't get much of a usable answer.
I think your best bet is either going to a dealer and asking what your timing is set at, or finding someone with a tuner.
Somebody with Cipher could read it to verify, just not set it.
with the BD you can check options on the truck, and it will show idle and if you have an advance.
I'm getting a bullydog. How will it tell me? I assumed it would just indicate my current value - say 17*. Is the 2008 factory default 15* or so?
worst case, just reset your truck to normal, then redo the advance along with the tunes and whatnot.
How do you verify a 2* advance?
BD: AKA Butt Dyno. You can feel the 2 degree down at the bottom of 2nd gear.
when you go into settings screen, you will see the advance either at -2, -1, 0, 1, 2.
so if it says 2, means you have +2 from factory, so yes the advance is on your truck already.
1 - 8 of 8 Posts
