21 - 36 of 36 Posts
83K and still goin
Im with eddie...I got 86,598 miles out of the stock brakes. I just replaced them last oct.
Edit: I also had 35in mud tires that worked like a parachute any time you weren't on the gas!
2012 at 30,000km shop said have 80% pad left
Got the brake judder done back when I had 22k miles. So from then till now @ 93k miles still on oem pads since 22k (replaced full set of pads with the judder tsb)
Yes, we're getting lots of miles on our pads (60K on mine so far). But the stopping ability of mine suck. A semi-metallic pad would stop better I suspect, even though it wouldn't last as long.
60k but my calipers oushed on side harder the outer pad had 1/4 pad left inner pad was gone...still havent changed the rear.
Welcome to the dark side, we have cookies here.
I just recently replaced my OEM pads and rotors at 98K. The rears had just started hitting the squealer
Super Moderator
I don't know how long mine would have made it if I'd kept them. At about 35k I upgraded them to slotted rotors. :eyebrow:
My 05 front inside pads were shot at 33,000 and the rears were worn 50%.
Just saw my post from '09 when I had my 08. Traded it in with 56k and pads were still good. My 2010 has about 63k on it and I'd say I've got a ways to go still before I need to change pads. I do have a slight judder at hwy speeds it I get on the brakes but it's not enough to make me pull the rotors yet.
Getting close to 85K on my 2010 with original brake pads. Starting to get a little shimmy and shake in the wheel under hard braking, so maintenance is close.
I just checked my brake pads on my 2011 Nissan titan. It still has the factory brake pads in place. i have almost 100 K miles on it, and the pads still easily have 70% life on them. All i did was clean up the rotors, calipers and the brake pads. I'm extremely impressed on the quality of equipment Nissan uses on the vehicles. (second Nissan I've owned).
21 - 36 of 36 Posts
