So, I finally got around to doing this today and figured I'd put up a brief how-to. It was surprisingly easy. I've never messed with anything drivetrain related before so I was pleasantly surprised. From start to finish it took me a little over two and a half hours. I'm by no means a pro and I did this with minimal knowledge and tools, just a bit of research and a couple hacks. I'll keep it brief, maybe this will help someone out. Here goes:
1. Remove hub cover and loosen wheel lugs (don't remove the lugs)
2. I chose to jack the truck from the crossmember using a 3 ton jack, with a 2 ton cross beam adapter (picture 1). It lifted beautifully. Just use common sense here getting the truck on to jack stands.
3. Once the truck is securely on stands with tires off of the ground, remove the lugs and tires. Personally, I slide the tires under the front for a bit of extra security in case the stands fail.
4. Relocate the jack under the lower control as close to the hub as possible to give it a bit of support. Don't jack too high though otherwise your truck will be tipping to one side.
5. Remove the cotter pin and nut on the hub. Sliding a screwdriver through the brake disc (picture 2) keeps the hub from rotating while you apply the torque. On my 2010 a 32mm socket with a breaker bar did the trick, though truthfully it took some convincing (picture 3).
6. Once the hub nut is off, move to the front differential flange and undo the 6 bolts. Remember, the axle spins so you can position it however you get the best torque. I only had a relatively short 14mm wrench handy so I spun the axle so my target bolt was at the bottom, placed the wrench on, and pressed it with my foot (pictures 4 and 5). All 6 bolts on both the driver, and passenger side axles came undone with a single press doing this.
7. Once all 6 bolts on the flange are loosened and/or removed, support the axle with your hand while you undo the last bolt. The axle should more or less fall right out. I was able to get the axle out without having to loosen or remove anything. No upper ball joint removal, or strut removal, however this could vary based on your suspension setup. All I did was push the differential side of the axle up and towards the rear of the vehicle until the splines of the axle cleared the hub and steering knuckle. After that, I was able to pull the whole unit out from the bottom without using even a pry bar or rubber mallet.
8. To reinstall, just reverse the steps. Slide the new axle up in to position, insert the splines in to the hub, reposition the flange and tighten down all nuts and bolts to torque specs. Installation/removal instructions are identical for both sides of the vehicle.
All in all it really was quite easy. Surprisingly so. Again your mileage with this method may vary based on your lift, however I can't see it being that much different. Worst case, you would need a 20mm (I believe, correct me if I'm wrong) wrench/socket and mallet to undo the upper ball joint, and the lower strut mount would need to be removed. The rest is cake.
Hope this helps someone. It's my first writeup so I apologize if it's left wanting. Criticism/questions are welcome. Enjoy!
