1 - 6 of 6 Posts
I am trying to figure out a way to give my 05 xe 2wd more control and traction especially off road. I dont think i have limited slip but i am not sure. i have heard that getting a truetrac helps and i know that is a differential but i am not sure if that is in deed what i need to do. i understand that a 2wd cant do everything a 4wd can do but i dont like getting stuck when i am out offroading. Is this what i need or something else?
2004-2005 Nissan Titan Detroit Truetrac® 32 Spline
Super Moderator
The TrueTrac is your only real option for an off-the-shelf way to get more traction. It's an excellent diff. Expect another $500 or so for installation.
Yes, that is absolutely what you need. The Titans don't have any kind of mechanical limited slip.
Discussion Starter #4
how hard to install?
Yep...the TruTrac is what you need....Very happy with mine so far....
Pretty extensive mechanical knowledge needed for this install. You have to have a dial indicator and know how to read it, lol, and know how to set backlash with it. If you've never fooled with differentials before, I would recommend getting someone experienced in the matter.
1 - 6 of 6 Posts
