1 - 3 of 3 Posts
I am going to wash my engine compartment and need tips on engine cover removal. I see two bolts in the back and can feel one under the front of the cover. Are there any more? I don't want to damage the cover and appreciate any tips. TIA.
Discussion Starter #2 (Edited)
Pretty simple. Just secured through 4X grommets on the engine cover onto 4 studs on top of the engine. No bolts to remove etc. Pull up on the front left (DS) gently and unsecure, then the front right, lift the front and gently pull the rear sides out towards the front to free the cover. Pretty impressed with the quality of the cover, especially the sound insulation on the underside of the cover.
545023
After a 15 to 20% simple green solution in water sprayed on a cold engine, followed by garden hose rinse. Now to dry the engine with a duster.
545024
1 - 3 of 3 Posts
