Like the subject says, I am trying to completely remove my leaf springs from the truck. I have the rear mounting points off from the shackle. The front mount of the leaf spring (towards front of truck) just spins. I only have access to the bolt head as the nut is recessed and I can't get to it to hold it in place. Any ideas or is there a trick I am missing?
I'm in a similar situation, however, I ended up cutting the bolt and now the nut is too big to remove from the slot between the bracket and frame. I think trying to bend it out enough to let it fall out will be the best bet, any thoughts?
i had the same problem when i installed my Deaver's on the Driver's side. the bolt kept spinning as i thought it was coming out. i'm really not sure how you would fix this?
Yeah what a royal PITA. One would think there would be a better mounting solution. I will mess around with it this weekend. I think on the other side I'm going to cut the bolt in half first, remove it and then cut the rest off so there is room for it to fall between the bracket and frame. I ended up cutting the channels that the bolt rides in out with a Sawzall to make more room but it was still not enough.
Quick update, I did what I mentioned above and cut the bolt in half on the other side and pulled the piece out. I then cut the bolt inside between the bushing and the bracket. This allowed enough room for the remainder of the bolt to fall out. Wish I would have done this on the other side during my first attempt. I still haven't gotten that original piece out. That is the last thing I need to do and I can begin reinstalling everything.
Gotta love how a simple brake swap to increase performance when towing my track car has now turned into several thousands in upgrades and replacements! I was thinking of trading it in but decided to just replace everything under the truck suspension wise. It's only got 88K on the clock so there is plenty of life in her. Now if I can only get that damn bolt out!!!
Wondering if anyone has a better solution for this? I have my truck at a shop to replace the forward leaf spring bushings and they are thinking about welding the nut to the frame. Was it welded to begin with?
Quick update, ended up using my sawzall and wedged the bolt against the frame with a lot of pressure and cut it in half. The pieces dropped right out! All back together and should be on the road this weekend.
Ok, I have to imagine there is a proper way, the engineers are allot of the time idiots, but always have a method, I have all new to go in, but what In god's name could be the solution, I am starting to wonder if the nut was indeed welded, and we all have just broken it
I'm definitely a lot late to the party. But I just took mine out by wedging a large standard screwdriver against the nut and used my impact driver to spin the bolt off. Nut is pretty chewed up from spinning between the guides, so now I need to find a new nut.
I was going to day that it probably needs to have something applying pressure while spinning. Its common for the bolts to get stuck in that sleeve and have to be pried out
Related Threads
Nissan Titan Forum
3.9M posts
143.4K members
Since 2003
Nissan Titan Talk Forum is a community for truck owners to discuss the Titan Cummins, Warrior, Midnight Edition and more!
