1 - 20 of 65 Posts
*** Edited March 30, 2009 ***
Added diagram for Crew Cab Trucks
*** Edited March 25, 2009 ***
Added a pair of relays in the mix so that a double pulse on the lock button would be required to roll up the windows.
Well I always thought it was cool that I could roll the windows down on the titan by simply pressing the unlock button and holding it for 3 seconds... I found it rather dumb that you couldn't press and hold the lock button and have them roll back up... Kind of sucks to run out in the rain during the summer to roll the windows up when Nissan could have added this feature from the factory.
Seems like everyone around here thinks the reason they don't roll back up is safety. That being said if you want to be able to roll them up here's how it's done.
*note when I originally started this mod I envisioned it to be much more complicated but it's really quite simple!
Materials Needed:
(1) Multi-Purpose Timer Relay (found mine at altronics.com - part # 6062)
various lengths of wire, i used blue, purple, black & red..
(2) Standard automotive relays (5 terminal was used in the example but 4 will work)
Instructions (King Cab)
**The basic setup is the same for Crew Cabs however some of the wires have changed location, please look below at the crew cab edit if you're having trouble locating wires.**
Step 1: Remove your drivers side door panel, everything you need is right inside. Start by removing the plastic trim at the door handle, the door handle "puller" and the arm-rest. There will be (2) screws in the puller, (2) at the handle & (1) behind the arm-rest.. (first photo) Then the door panel will pop off, it's attached using orange push in fasteners. Next reach behind the panel and detach the cable going to the latch & door lock. Finally pop off the puddle light & switch panel. & disconnect the wires.
Step 2: Locate the following wires in the larger of the two harnesses that you disconnected from the door/window switch.
White/Red heavy gauge > +12 volts Constant
Black heavy gauge > Ground
Blue > lock cylinder wire
I slit the insulation on the door right above the speaker to chase my wires up to the door switch, there's ample room behind the door panel at this location to mount your timer. Strip each wire back and connect the wires here and make up your connections (I solder everything but to each his own)
(see picture 2)
You'll need an enclosure of some sort for the timer as it comes in just a cardboard box. I used an empty butt splice box since this was an experiment i'll pick up a plastic project box to finish it off.
On the switch panel I connected red to white/red, blue to blue, and black/yellow to black these wires hook up to the altronix timer using the following terminals.
Red to the + terminal
Black to the - terminal
A jumper from the - terminal to the NO (normally open) terminal
Blue to the C (common) terminal
Step 3:
The final wire we need to connect is the door lock wire, this wire is NOT located in the switch wiring. If you go to where the pull cables for the handle & lock come out of the insulation and slit the foam you'll find a bundle of wiring. The wire you want is the purple one, heavier gauge.
(see picture 3) This wire gets 12v pulsed to it whenever you trigger lock button on the keyless fob. Strip it back and connect a wire here, i used purple. Chase it over to the timer module and connect it to the TRG (trigger) terminal.
Timer setup. You need to set the dip switches on the 6062 timer module to the following settings:
1=OFF
2=ON
3=ON
4=ON
Then set the timer for just below 15 seconds, you may have to fine tune it depending on how fast your windows roll up.
**** Edit Addition of relays to require a double pulse to roll up windows ****
1) Disconnect the wire connected to the "C" terminal of the Altronix module this wire goes to the lock cylinder wire.
2) See diagram below to wire up the relays.
NOTE: This diagram is only good for King Cab Models, See Attached Diagram For Crew Cab Models
a) Connect the wires going to terminal #30 of both relays to terminal "C" of the timer module.
b) Connect the wire coming from terminal #86 of relay #2 to the "+" terminal on the altronix module. (12v+ constant)
c) Connect the wire coming from terminal #86 of relay #2 to the "TRG" terminal on the altrronix module. (trigger wire)
d) Connect the wire that was connected to terminal "C" in the original mod to the yellow wires (terminals #87 on relay #1 & #2)
- What this does is when you hit lock the first time, the timer starts, it then grounds relay #1 & #2 allowing them to activate. When you hit lock a second time relay #1 energizes, in turn energizing relay #2. Relay #1 only stays active for a second (due to the door lock pulse) while relay #2 will remain active until the timer expires.
*********** END EDIT ***************
*********** Crew Cab Edit ************
See attached diagram at the bottom of post for a crew cab diagram.
The CC and KC differ slightly but the connections are in the same location, when you disconnect the connectors on a crew cab you will have one sixteen pin connector, and one three pin connector. The power/ground for the windows/timer will be tapped into the smaller 3 pin connector..
1) Connect a wire from pin #19 (white with red stripe) to the (+) terminal of the timer module.
2) Connect a wire from pin #17 (black) to the (-) terminal of the timer module.
3) If NOT using relays for double pulse. Connect a wire from the (C) terminal on the timer module to pin #4 in the large white harness (blue wire) *note there are two be sure to pick the one in position #4!
--OR--
If using relays for double pulse, connect the wire from terminal #87 of the relay's to pin #4 on the 16 pin white harness.
*NOTE this to my knowledge does not affect the rear windows, unless your rear windows will roll up with the key in the door this mod will not cause them to do so!*
Notes/Disclaimers:
This mod uses all factory systems, so the limit switches and such all function exactly as they should. When the lock wire is triggered the relay sends a ground to the blue wire, tricking the truck into thinking that the key is in the lock cylinder being turned to the lock position. It then rolls the windows up, if one window is faster the limit switch kills the power to the motor so there shouldn't be an issues if one of your windows is down farther than the other.
The white/red wire has +12 volts on it at all times, if you touch this to ground while you're stripping it or making connections you're likely to blow a fuse. Disconnect the negative battery cable to prevent shorts.
The module is set for x time decided by you, if you have your arm in the window and roll it up it isn't smart enough to stop you'll have to wait for the limit switch to kick in or the timer to end, roll limbs up in the windows at your own risk.
Video:
2005 Nissan Titan window rollup mod in action
Very nice write up!:thumbsup: I am very interested in doing this mod to mine.
Thanks, if anyone has trouble getting these modules drop me a line you can have em for cost + shipping (long as none of the mod's object) I picked up two of them and they were about $18.00 each. I Don't know if altronics will sell directly to the public, i buy alarm components from them.
KP Technologies offers a similar unit for $49. Sounds like yours is less expensive.
AWESOME!! :redblob" One more reason I joined this here forum!
Great write up and great mod as well
Interesting. I have the rollup and down function as part of my remote starter.
Banned
Awesome write-up! I've always wanted the remote to roll the windows up.
I don't know that I'll tackle this quite yet (something about cutting into wires on a truck with less than 10k) but this is the type of stuff I get into when I'm bored. Thanks for the great writeup!
really nice write-up...just curious for those of us with crew cabs...has anyone thought of making all 4 windows roll down...then back up, thats what i need to know, any help would be great
Discussion Starter · #13 ·
Do the crew cab models have a keyed lock on them? If so can you roll them down using the key in the door? If so it wouldn't be very hard to adapt this to the crew cab models. I'll look in the manual at the wiring and see just how its wired to see what it would take.
That is awesome. I think I need to do this.
any help in the manuel...really itching for this mod
This should work the same with after market alarm, windows and locks right?
OMG thank you for this write-up! finally someone did it! THANKS
i demand this be a sticky
Discussion Starter · #20 · (Edited)
If your aftermarket alarm allows you to hold down unlock to roll the windows down then you will still retain that feature as it's built in via the factory. It will work as a rollup module for an aftermarket alarm as well regardless as it just makes the truck think you have the key in the lock turning it to the lock position.
so do the windows roll up every time you hit the lock button?
NO.
As long as the ignition is on they will operate as if the mod wasn't in place. Remove the key from the ignition and they will roll up, apparently the factory window control has some sort of logic that tells it to ignore the key in the lock signal if the ignition is on. Therefore the windows and door locks operate as expected. I have however noticed if you use the rolldown feature using the fob the windows will go back up when the truck auto locks. The only work around I have for this at present is to vent your windows when you get out I'll figure out a way around this and post back.
1 - 20 of 65 Posts
