1 - 10 of 10 Posts
Banned
P-Dizzle said:
Amping the factory speakers will help but I would not recommend if your not adding a sub too.
why not? i was MAYBE thinking of putting a small 6 inch that would fit under the front passenger seat. why wouldnt you recomend i tthough?
Wht amp would you recomend for stock HU, stock speakers, and maybe a 6 inch sub?
Supporting Vendor (Gold)
Even if you add more power the factory speakers are going to distort something terrible. Adding a sub would help mask that. If you don't want to add a sub I would replace the speakers with some components and then amp those
I wouldn't suggest just adding an extra amp.
The stock speakers are powered well enough, and any extra power will just distort them, and add to the chances of them blowing. Also, I haven't look at the speakers in the Titan yet, but usually stock speakers have odd impedences unlike afermarket speakers. But that isn't always the case. I would suggest getting a new set of components or adding a sub to the stock system if you want a better sounding audio setup.
2 ohm in the doors and 4 ohm in the dash. If you add an amp to factory speakers you will need to cross them very high.
i have a amp funning my factories and the distort like crazy. if you just turn up the volume on you factory HU they will distort also. save your money...
Banned
Discussion Starter #10
k thanks
1 - 10 of 10 Posts
