1 - 20 of 29 Posts
I've decided that I really want to lift my truck. I was originally planning on just the mini-lift but like the look of a little more lift than that. Right now my top two choices look like the 7" cst package or the 4" prg performance package. I haven't seen many trucks on here with the performance pkg., is it the same height as the 4" rancho lift? Also what would be the easiest way to get a couple of inches more out of the performance lift? Thanks.
I just purchased the 4" Performance Package with Sway-Away rear shocks and TC Shackles. When I talked to Greg he said I would get about 3 1/2 inches out of the front Sway-Away Coilovers on my 4x4.
Do you have the kit installed yet? Interested in how it rides vs. stock.
Just ordered it a week ago, so not installed yet. I will be sure to post some pics and I'll let you know how it performs.
Also I've found the fabtech lit for $1299 with no shocks, how would you spend the rest of the money to complete that kit?
Does anyone have pics of a 33" tire, preferably m/t, with a 6 or 7" lift. It seems like eveyone runs 35s when they get lifted.
Is your Titan a 2wd? If so get the PRG 4" spindle lift, (click on the link in my sig, it's the 1st pkg, not the 2nd one like I have), And then, get the DR coilovers to go with it. Set them for 0" lift, since you will get 4" from the spindle. This should be close to $2K.
If you have an extra $500 or so, get the mid-length PRG-valved SAWs and the PRG upper A-arms instead of the DR coilovers.
BTW, my 4x4, (can't use the 4" spindle :mad: ), is set for about 3" in the front. Click on the sig pic for more pics. My tires are aftermarket 33" BFG AT KOs.
I've been super happy w/ my PRG 4" performance package for my 4x4. I got the SAW's w/ the TC uppers in the front and Deaver's w/ Radflo resevoirs in the rear. And best of all a friend and I put it on for a case of beer and a pizza.
Super Moderator
Just my personal opinion, but I would go with the PRG 4" lift.
I was originally going to get the 4" performance lift, I'm not a fan of lower crossmembers. Once I got my DRs on with my rear blocks, I decided that was enough for me. My 33" BFG MTs look great on it and fill the wheel wells just enough to make my Titan look stock from a distance. The leveled stance looks good but I would have to get airbags for the rear for those occasions when I'm loaded down or towing.
Your truck looks awsome. Do you get any rub with those wheels and tires and how wide are your wheels?
I don't plan to lift my truck but when I do my suspension work, it will be with PRG.
Do get some rub. Not a lot though. Just a small bit of the pinch weld was removed to stop it via sawzall. My wheels are 17x8's. I ran the same tires on my off road rims w/ just the PRG leveling kit and had a small amount of scrub then too.
I just spent close to 1,000 on my suspension. I bought the sway away front coilovers and a one inch block for the rear. I only cranked the saw's about 2.5 inches because i didnt buy the prg uca. The ride is better, just installed this weekend so i have not got the chance to test it offroad yet but i plan to soon.
splifrover said:
Yeti77: How much do you have them cranked? Also, what can of bikng do you do? I have a dj/4x bike I'm trying to sell.
I have measurments at home. At work today so can check later if I have time or will look tomo when I get home. I used to mtn bike a lot before I moved to FL. Trying to get out of here though. I have my 97 or 98 FRO I forget when I bought it. Still love it. One day if I get out of here and back into riding more I will buy a full susp Yeti.
I would shoot for the PRG 4" Performance Kit w/PRG upper arms. I know this will put your budget a little over the 2k, but you'll get the most performance out of it.
Greg has a couple of frt shock options, and the kit gets rid of those f'ed-up overload leafs from the rear spring pack.
You can always add the lift spindles later as you save up a little more scratch, and it will bolt right on!
You have a 2wd, correct?
I paid 2100$ and got PRG Upper Arms, SAW Front and Rears, TC Shackles, and the 1" Spring in the rear. Everything just got here in the mail today. So excited! Hopefully I can get it installed this week. I'm going to run this with 35inch BFG Mud Terrain KM2 on either stock wheels or mojave teflons, so there goes another 2500$. I'm going to be poor, but damn it is going to be worth it.
I got a real good price on my Amer Racing Fuel 8 teflons on performanceplustire.com Lot less than some 4x4 online sites.
1 - 20 of 29 Posts
