Howling noise
1257 2
Hello,
I have a '06 Nissan Titan and lately I've been hearing a howling noise. I think it's on the right side back, but not really sure. It's only when I push on the gas pedal and going between 60-70 mph. When I release the gas pedal, the noise is gone. When I push on the gas pedal to accelerate and if it's between 60-70 mph, the howling noise is there. I've taken it to Nissan and had a 15,000 done on it, rotate and balance tire and also an alignment. Still the same problem. Just wondering if anyone have seen this before and if this has anything to do with the bearings? If so, will the warranty cover this repair?
Thank you all in advance.
1 - 3 of 3 Posts
I have the same problem after a 2 inch lift to the front. It also starts a 60 MPH. The dealer could find nothing wrong but now its on record as maybe being a problem after the warranty runs out. Get it checked out by a dealer, get it on record.
Probably your differential singing from the ring and pinion. Some have that problem. Be sure you check diff oil level and color. Make sure you check/change at correct intervals. Take it to the dealer and tell them the diff is making noise.
1 - 3 of 3 Posts
