Thanks for posting OP!
Welcome again and Great to have you on here!
I for one have always wanted to know more about the HP Tuner for the Nissan Titan! I was super excited when I first heard that you guy's were going to support our platform!
I've had my '05 Tuned by Up/Rev since way back in January of '08.
Back then Up/Rev was really just getting started and the Titan Community was so happy to finally get a real Tuning option!
So I think it's great that a large Tuner company such as HP Tuners is offering support to the Nissan Titan platform! A LOT of the other Tuner companies wouldn't give us the time to develop software for our trucks.
Where should we go to learn about the features offered for the Titan?
Some of the things I'm interested in learning about are:
- The list of engine parameters that are capable of being logged,
- BCM funtions
- Also just seeing pics or videos of how the live engine data monitoring / data logging software looks on screen?
Thanks,
GW77
Gweasel77,
To learn more information about what features are offered for the Titan platform, the forums would be the best resource to explore. If you have any specific questions about features, our support team can help answer them. In terms of logging parameters, the list is quite long. Here is a sample of what is capable, excluding SAE parameters. In terms of BCM functions, what specifically are you looking for? The best place to see how our software looks and functions would be through YouTube. There are lots of examples of how our software is set up. Hope this helps!
Broadcast parameters
Transmission Current Gear
Common Identifiers
Engine Coolant Temp
Vehicle Speed
Battery Voltage
Intake Air Temp
Spark Advance
EVAP Purge
Fuel Temp
Fuel Tank Level Sensor
EVAP System Pressure
Absolute Engine Load
Engine Oil Temp
Short Term Fuel Trim Bank 1 Avg.
Short Term Fuel Trim Bank 2 Avg.
Long Term Fuel Trim Bank
Manifold Absolute Pressure
Idle Corrected RPM
DI Start of Injection Angle - Intake (DI Titans only)
Intake Cam Control Solenoid Bank
Radiator Fan Duty Cycle
AC EVAP Temp
AC EVAP Target
VVEL Sensor Learn - Bank
Engine Sped
Distance Since Last Code Clear
Mass Airflow Sensor Volts Bank
Injector Pulse Width Avg Bank
Theoretical Injector Pulse Width
Mass Airflow
APP Sensor
AC Pressure
Wideband Volts Bank
Cruise Set Speed
Intake Cam Angle Bank
VVEL Position Sensor Bank
VVEL Timing Bank
High Pressure Fuel Pump Commanded Angle (DI Titans only)
Memory Parameters
Volumetric Efficiency
Final Spark
EQ Ratio Multiplier
Piston Slap Retard
Knock Correction (+Adv/-Ret)
Torque Converter Speed Ratio
Fuel Pump Fuel Mass
Airflow Quantity Ramp Rate
Enrichment Retard
MBT Trimmed Advance
Trim Advance
Cranking Advance
Ignition Coil Dwell
Engine Torque
Spark Base Advance
Knock Count
EQ Ratio Commanded
Cat Lightoff Retard
Idle Advance
MBT Advance
Octane (Low/High)
Engine Afterstart
Atmospheric Pressure Compensation (Fuel)
Intake Air Temperature Compensation (Fuel)
