HVAC Air Mix actuator help needed
1642 0
I've seen posts on the replacing part 27742-zp00a with simple instructions to remove the 3 5.5mm screws and replace this part. I have tried and can't get to the screw head in the back. I dropped the BCM and still can't get the screw because of a bracket that (has what appears to be spot welded brass nuts) blocks access from allowing a socket to grab it.
Can this really be done DIY or does the dealer have to get mega cash to replace the $40 part??? Suggestions...
Thanks -
