2008 Titan XE
There are a few weird things going on with the pickup. I have no power (lights or controls) for the buttons on my HVAC controls and my fan is stuck on high. I also have some other weird things that could be separate, but happened at pretty much the same time the controls stopped working, so it’s hard to believe it’s coincidence. There is no ding when ignition is turned on or door is open, and it just has 2 dashes where it’d typically display an outdoor temperature. Also the solenoid for the shifter won’t disengage and allow me to shift. Everything else in the truck works just fine except these things.
So far I’ve replaced the HVAC control section itself and also the IPDM board. Nothing has changed a bit! I’m going to order a new VBC next but I’m not sure if the other issues would point to something else causing all these issues.
