Probably the wiring harness routed through the rear doors. Though there are 2 other recalls as well.
Results : 3 | All records displayed
Make : NISSAN Model : TITAN Year : 2006
Manufacturer : NISSAN NORTH AMERICA, INC. Mfr's Report Date : FEB 28, 2006
NHTSA CAMPAIGN ID Number : 06V064000 N/A
NHTSA Action Number: N/A
Component: LATCHES/LOCKS/LINKAGES
OORS:LATCH
Potential Number Of Units Affected : 427
Summary:
CERTAIN LIGHT TRUCKS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 206, "DOOR LOCKS AND DOOR RETENTION COMPONENTS." AN ARC WELD IS MISSING ON SOME RIGHT SIDE REAR DOOR UPPER LATCH ASSEMBLIES.
Consequence:
THIS MAY RESULT IN THE RIGHT SIDE DOORS COMING PARTIALLY OPEN INCREASING THE RISK OF INJURY TO OCCUPANTS.
Remedy:
DEALERS WILL REPLACE THE UPPER LATCH ASSEMBLY FREE OF CHARGE. THE RECALL BEGAN ON APRIL 3, 2006. OWNERS MAY CONTACT NISSAN AT 800-662-6200.
Notes:
NISSAN RECALL NO. PB017. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO
HTTP://WWW.SAFERCAR.GOV.
Check to Request Research. Submit below.
Manufacturer : NISSAN NORTH AMERICA, INC. Mfr's Report Date : NOV 22, 2006
NHTSA CAMPAIGN ID Number : 06V459000 N/A
Component: ELECTRICAL SYSTEM
Potential Number Of Units Affected : 96500
Summary:
ON CERTAIN KING CAB TRUCKS, THE WIRES IN THE HARNESS WERE ROUTED THROUGH THE REAR DOORS AND INTO THE BODY. THESE WIRES MAY BREAK DUE TO OVER BENDING OF THE HARNESS AS THE DOOR IS OPENED AND CLOSED. THE HARNESS CONTAINS WIRES FOR THE DRIVER SEAT BELT PRETENSIONER AND FOR THE FRONT PASSENGER SEAT BELT WHICH IS PART OF THE OCCUPANT CLASSIFICATION SYSTEM. WIRES FOR THE REAR AUDIO SPEAKERS ARE ALSO CONTAINED N THE HARNESS.
Consequence:
IF THE WIRES FOR THE SEAT BELTS AND SPEAKER WIRES BREAK AND MAKE CONTACT, THERE IS A POSSIBILITY THAT THE PRETENSIONER MAY DEPLOY. IF THIS HAPPENS WHEN THE SEAT BELT IS RETRACTED, IT WILL NOT BE POSSIBLE TO USE THE SEAT BELT. IF ONE OF THE WIRES ON THE RIGHT SIDE HARNESS FOR THE SEAT BELT TENSION SENSOR BREAKS, THE PASSENGER SIDE FRONT AIR BAG WILL NOT DEPLOY AS DESIGNED IN A FRONTAL COLLISION INCREASING THE RISK OF A CRASH AND PERSONAL INJURY.
Remedy:
DEALERS WILL REPLACE THE WIRE HARNESS COVER WITH A DIFFERENT TYPE THAT PREVENTS OVER BENDING OF THE HARNESS AND THE HARNESS WILL BE REROUTED FREE OF CHARGE. THE RECALL BEGAN ON FEBRUARY 19, 2007. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Notes:
Manufacturer : HOPKINS MANUFACTURING CORP. Mfr's Report Date : JUN 25, 2007
NHTSA CAMPAIGN ID Number : 07E046000 N/A
Component: EQUIPMENT
Potential Number Of Units Affected : 3500
Summary:
CERTAIN HOPKINS AFTERMARKET TRAILER BRAKE CONTROL CONNECTION HARNESSES SOLD FOR USE ON CERTAIN MODELS OF NISSAN VEHICLES WHICH ARE LISTED ABOVE. THE INTERNAL PART NUMBERS WITHIN HOPKINS ARE: 1010476025, 1040376025, 1110476025, 1170376025, 1290376025, 1010476035, 1040376035, 1110476035, 1170376035, AND 1290376035. A WIRE MAY HAVE BEEN PLACED IN AN INCORRECT POSITION IN THE ELECTRICAL CONNECTOR HOUSING. THIS RESULTS IN AN INCORRECT ROUTING OF WIRES BETWEEN THE TRAILER BRAKE CONTROLLER AND THE TOWING VEHICLE WIRING SYSTEM.
Consequence:
THIS HARNESS WOULD RESULT IN POWER FROM THE TRAILER BRAKE CONTROLLER GOING TO THE TOWING VEHICLE DASH LIGHT CIRCUIT RATHER THAN THE TRAILER BRAKES. THIS RESULT WOULD BE THE LACK OF TRAILER BRAKING WHEN THE TOWING VEHICLE BRAKES WERE APPLIED. IT WOULD ALSO RESULT IN THE TOWING VEHICLES DASH LIGHTS BEING ACTIVATED WHEN THE VEHICLE BRAKES WERE APPLIED. THE FAILURE OF THE APPLICATION OF THE TRAILER BRAKE COULD RESULT IN REDUCED ABILITY TO STOP AND CONTRIBUTE TO A POSSIBLE CRASH.
Remedy:
HOPKINS WILL NOTIFY OWNERS AND REPLACE THE ORIGINAL HARNESS WITH A REVISED HARNESS FREE OF CHARGE. THE MANUFACTURER HAS NOT YET PROVIDED THE AGENCY WITH A NOTIFICATION SCHEDULE. OWNERS CAN CONTACT HOPKINS AT 800-835-0129.
Notes:
THIS RECALL ONLY PERTAINS TO AFTERMARKET HARNESSES AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON VEHICLES MANUFACTURED BY NISSAN. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO
