I have an 05 SE CC 4X4 and the truck is dying on acceleration. I have to be very very careful(slow) when I take off from a redlight or the truck will die. It's also backfiring and the RPM's are fluctuating back and forth when this is occurring or about to die. I then have to put the truck in neutral turn the key for SEVERAL seconds before it'll fire back up and then, once again, take off very, very slowly. The only 3 codes are: P0430, P1446 vent control valve (is this why my gas is spitting back out of the filler neck after every .90 cents or so worth of gas and takes forever to fill up!!!) And P0037 HO2S heated control circuit low, bank 1 sensor 2 thanks in advance guys I've had nothing but problems since I got this truck.
