1 - 2 of 2 Posts
I installed the factory air intake. I need a pic of the mass air flow sensor installed in the tube. I cant remember if the plastic washers are used with the factory set up or not. So if you have a factory air intake i would like to see it. just to make sure mine is right or if i have to fix it....
Also would the ECU have to relearn the factory air box setting it seems that since i put the new tires on it's been sluggish. The pedal responce is there but it just seems sluggish. Would it be the extra weight of the tires???I hope the MAF sensor isn't bad.
Thanks
im pretty sure if the maf sensor was messed up the truck would run like ****, and itd throw a code..so if its not doing any of that i thin youre good to go.
1 - 2 of 2 Posts
