i need help please.
568 2
i just don't understand ANY of the things i am reading about tire/wheel size, spacing, offset, etc. it just DON'T MAKE SENSE! haha (i'm not yelling)
i want moto metal 951 black 20" wheels. i'd like the nitto TG in 305/50/20.
(I have no lift or anything btw)
soooo...what offset do i need to get? i don't want it to be flush like my stock tires are..i want them to stick out just a little.
BUT
i don't want to have to do any trimming or what not.
i've asked before, but i just don't understand offset and backspacing and all that jazz..
can anyone dumb it down A LOT for me?? (and be as blatant as you want- i dont mind..):bangit::bangit::bangit:
1 - 3 of 3 Posts
Ok I'll try. Back spacing has to do with the inside of the wheel from where the face of the brake rotor is towards the inside of the truck. Offset is how the wheel looks to you from the outside the part you see. Ok lets just use basic wheel sizes and try to tell you what it means. Lets say you have a 18" wheel and it's 8" wide and has a 0 offset and a 4" back space. That means the spokes or where the lugs mount are in the middle of the wheel,the outside of the wheel would have a 4" lip the part you see kinda like what you want. Now if the wheel had a 2" positive offset then the outside would have a 2" lip and 6" back space. Understand? Negative offset has a lot of lip or dish to it, a lot of cars and trucks from the old days ran alot of negative offset. Modern cars seem to run alot of postive offset no lip. The problem with adding negative offset to your truck without any lift will cause the tires to rub or worse. When you add a lot of negative offset and reduce back spacing it pushes the wheels out, makes the overall width of the track wider.
I don't know what the specs are on the factory wheels, I'm sure you can find it here or someone will chime in. I would try to keep your new wheels as close to factory specs or go with a wheel that others are using.
Hope this helps.
Hope this helps.
thanks that makes much more sense. so would i be okay with the wheels/tires i want to get? or would i have to trim or alter anything? the choice is 18 offset and 35 offset i believe..
1 - 3 of 3 Posts
