1 - 6 of 6 Posts
hey guys, i'm looking to get 20" kmc rockstars on my 04 titan. i have a 6" pro comp lift on the truck. i need to know what rim width slash backspacing i will need to use. i would like keep the tires tucked under the truck as much as possible. in other words i dont want my tires sticking way out. thanks alot boys. pics would also be nice.
I would go 20x10" with a 0mm offset or +10 I can't remember which one they offer on that rim. It will stick out a bit but not too much.
These would stick out about 9/10 inch more than stock rims.
20" x 8.5" +10 mm offset 5.14" backspacing 6x135/6x139.7
20" x 8.5" +10 mm offset 5.14" backspacing 6x114.3/6x139.7
The 10's have a -24 mm off and 4.56" backspacing, and would stick out about 3" more than stock.
^^^^ these will be exactly what you want. I have them and they are flush so with a 35" tire they might stick out a 1/2" more but again this is the best you'll do......5.14 BS, +10 offset, 20x8.5.
20x8.5 rockstar with 5.14 BS & +10 offset
Here is what mine look like with a level...
This is what the same rim will look like with a 6" procomp.....
1 - 6 of 6 Posts
