Can't he just get the extended coil overs and bigger blocks? He already has the 6" lift. The extra tall kit comes with the 6" fabtech lift which he already has (procomp same thing).What he said ^^ For what you want, you need the PRG Extra Tall Lift which is a Fabtech lift with full length coilovers and a spacer. You'll be sittin' at about 12" lift when you're done
Same exact thing you did.Does anyone know what Ed Fonzareli did to his truck to achieve that height? I'm diggin it!!!
You have to have the Fabtech to do the extra tall lift because the fabtech spindles are slightly bigger/taller than the pro comps making everything workCan't he just get the extended coil overs and bigger blocks? He already has the 6" lift. The extra tall kit comes with the 6" fabtech lift which he already has (procomp same thing).
