1 - 6 of 6 Posts
40-50 miles since there is usually at least five gallons left in the tank.
Clint
Super Moderator
Clint is spot on as usual. Just one thing to add. Don't let your tank go dry. You might burn up your fuel pump if you do. Gas light = fill up soon!!!!!!!
ive filled her up a couple times after the light went on, and never was able to add more than 22 gallons!..... so that means i had at leat 4 gallons left before it would run dry, tho thats 45 to 60 miles at best.
Well I'm not fully sure on mileage. I for some reason don't pay attention to mileage to and from work but I just went from monday through friday with my light on the whole time. No problems though! If only the light came on at a more reasonable time, like per say 3 gallons. First time the light came on I filled it up and still had at least 8 gallons left in the tank. Probably didn't help at all but still! Good luck!
1 - 6 of 6 Posts
