04 Titan LE... The steering wheel IS NOT locked. and the key will not turn in the ignition to turn the vehicle on. When you wiggle the shift knob around, you can hear a solenoid clicking, but the key still will not turn. Eventually, with enough fidgeting of the steering wheel/ignition/and shifter...something works and it turns and is able to be started. Wondering if anyone has had this issue? And if so, how easy of a fix is it?
Try this
Try this
Damnnnnn, that is an expensive fix. Thats unfortunate as this vehicle has been nothing but problems since bought from the dealer. First the Camshaft position sensor causing complete shutdown of the vehicle while driving.. to the bank 1 sensor 2 code it mysteriously throws on and off... it wasnt even registered in the state of california when they sold it to us, and still wasnt when driven off the lot and home to be registered. Theyre good trucks, I guess if you get lucky.
You have a bad O2 sensor did you replace it? It’s the passenger side rear one
