Considering bringing a Titan from Washington to Canada. The Registrar of Imported Vehicles requires "an electronic immobilizer system that meets Canada Motor Vehicle Safety Standard (CMVSS) 114". Does anyone know if the 2005 Nissan Titan is equiped with that? Thanks. :bangit:
My Titan has electronic immobilizer built into the key. I think they all do? Probably meets the requirement for you...
Reactions: macker
don't know if this helps but it says after 2007:
Every passenger vehicle, multipurpose passenger vehicle, truck and 3 wheeled vehicle manufactured after September 1, 2007 and with a Gross Vehicle Weight Rating (GVWR) less than 4,536 kg (10,000 lbs), except an emergency vehicle or a walk-in van, must be equipped with an immobilization system as per the requirements of CMVSS 114.
from EXPLANATIONS -  Vehicle Showroom - Autos - MSN CA
from EXPLANATIONS - *Vehicle Showroom - Autos - MSN CA
If it is a 2005 you are asking about, it is exempt by this standard as it was manufactured BEFORE 9/1/07.
So yes, it is admissable into canada.
http://www.carswithoutborders.com/wordpress/wp-content/cmvss-114.pdf
info at above webpage.
Reactions: macker
You should be GTG.
