Ok guys. 2008 crew cab Titan w/ tow package. When driving 60ish there is a loud humming noise similar to a wheel bearing going out on a car. Louder than my tire noise. But as soon as I let off the gas and coast, the noise goes away. When I step on the gas, it comes right back. It's getting noticeably louder.
-Checked the transfer case fluid, good (changed it less than a year ago).
-Checked the rear diff fluid, full but needs changed (will do that soon).
-Removed rear wheels and checked for slop/ play in the axle bearings, none.
-Checked for slop/ play in U-joints, none.
-When under the truck with it on the ground, if I try to turn the drive shaft, there is about 1/8" of play.
I don't know if this is related, but I have a clicking noise coming from the rear end more so when it's cold or I'm turning. I think it's the drivers side. Checked parking brakes, they seen fine.
I suspect my rear end, but how does one verify this? Any other ideas or things to check?
