It's the same engine, but the Titan engine is set more for endurance, and a little less hp. That's my understanding.lizardking said:Did anyone notice that the Infiniti QX56 has same engine as the Titan putting out 315HP and 390lb-ft. Now since Infiniti and Nissan our one in the same do you think the hp/torque on the Infiniti is what where seeing on the Titan :cheers:
Generally all you have to do to get a few more hp is use a less restrictive exhaust system. It probably also has a slightly different ECU program which allows the engine to squeeze out a few more ponies.lizardking said:Did anyone notice that the Infiniti QX56 has same engine as the Titan putting out 315HP and 390lb-ft. Now since Infiniti and Nissan our one in the same do you think the hp/torque on the Infiniti is what where seeing on the Titan :cheers:
Hey i just realized the little avatar i put in at the bottom isn't a very nice one. Sorry about that...i didn't mean to give anybody the double finger i thought i was giving a thumbs up.Sabre66 said:Generally all you have to do to get a few more hp is use a less restrictive exhaust system. It probably also has a slightly different ECU program which allows the engine to squeeze out a few more ponies.
With most cars these days you can buy an aftermarket ECU that remaps the engine profile and increases hp/torque. I'm sure someone will come out with one soon. :futwice:
bwahaahahaa that IS funny....you were being all informative about hp and stuff and then ended it off with a nice little birdie...i was confused :huh:Sabre66 said:Hey i just realized the little avatar i put in at the bottom isn't a very nice one. Sorry about that...i didn't mean to give anybody the double finger i thought i was giving a thumbs up.
:jester:
