1 - 10 of 10 Posts
Your SES light should have been on if there is a gross leak.
Well, I thought most EECS were designed to trap vapors from the gas tank inside some sort of charcoal based canister. Maybe replacing the canister would do the trick as the existing one might be saturated. I suppose you could also have a leak somewhere in tubing or conduit connecting the tank to the system. I believe there is also a purge valve that can go bad.
I believe there is a 100,000 mile warranty on emissions controls. Take your failure notice to the dealer and let them figure it out.
So you took your truck in for state inspection with the SES light illuminated? Why would you do that?
If there is a gross leak, then my guess is some tubing is disconnected or has holes in it so that vapor isn't getting to the canister properly. It is probably easier and cheaper to just replace the tubing first and see if that does the trick.
As stated above, assuming you have less than 100k, the dealer should take care of this issue.
the emissions are not covered by a 100k warranty. and only some emissions items are covered by the federal mandated 8yr-80k mile warranty, most notably ECM and catalysts. the gross leak could be caused by a broken hose, faulty vent valve, broken canister, loose/poor sealing fuel filler cap, etc...
Replace the cap first and reset your ecu. If that doesn't fix it then take it to the dealership because if could be many different things.
1 - 10 of 10 Posts
